Paulj504
Apr 14, 2020Aspirant
100203001 Commit Failed
I recently found I had a very low amount of free space and I lost some ability to remotely use via ftp. I susbsequently have deleted about a TB of space and I am now running at about 75%. Unfortuna...
- Apr 14, 2020
Paulj504 wrote:
I recently found I had a very low amount of free space and I lost some ability to remotely use via ftp. I susbsequently have deleted about a TB of space and I am now running at about 75%. Unfortunately, I have lost ftp access to some of my shares. If I try to disable / enable ftp or add another user to my shares, I get the error above.
Unfortunately, this is a system to which I only have remote access, although I do have ssh which seems to have full access to the system.
Perhaps the OS partition is also full. Have you checked for that with ssh?
Apr 14, 2020Guru - Experienced User
- Paulj504Apr 15, 2020Aspirant
Thanks, Steve, You guess seems to have been absolutely correct. The system volume was pegged.
Although, not having *any* real sysadmin skills, I was mightily challenged to run this to ground and create a fix. It seemed to be a very odd circumstance in which a USB drive was left in the machine months back with a number of large media files on it. Deleting those seemed to create a huge release of space on the system volume. I'm guessing they must have been cached or mirrored in some fashion on the system volume.
- StephenBApr 15, 2020Guru - Experienced User
We've seen this before. They aren't cached or intentionally mirrored. The USB drive uses /media as a mount point. If the drive is somehow dismounted, and the backup job doesn't detect it, then the files end up in /media. I think it could also happen if the USB drive is written in other ways.
