carpii
May 30, 2015Tutor
2 disks died at once :(
I shutdown my ReadyNAS Pro 4 this morning (Radiator 4.2.27) , but when I rebooted it an hour later, 2 of the 4 disks were suddenly marked as dead. The NAS wasn't physically moved, and its on a UPS ...
vandermerwe
May 30, 2015Master
carpii wrote:
I stock all 3 of my ReadyNASes with 2TB Western Digital RED drives (on]
The drives in the readynas you're writing about are not RED drives, although the RE drives are also on the HCL.
From the tone in your OP I would guess that the data on the pro 4 is backed up or easily replaced?
It is possible that 2 drives would fail like this, but it's odd and worth looking for another cause.
Check the drives as suggested.
