carpii
May 30, 2015Tutor
2 disks died at once :(
I shutdown my ReadyNAS Pro 4 this morning (Radiator 4.2.27) , but when I rebooted it an hour later, 2 of the 4 disks were suddenly marked as dead. The NAS wasn't physically moved, and its on a UPS ...
May 30, 2015Guru - Experienced User
And they are enterprise drives.
vandermerwe wrote: The drives in the readynas you're writing about are not RED drives, although the re drives are also on the HCL.
FWIW, double drive failures do happen, and drives will fail suddenly and without degradation of SMART stats. Though usually the second one fails on resync.
Is it possible that one drive failed earlier, and you simply didn't notice? (I realize no drive failures are in the log snippet...).
