netghiro
Nov 09, 2016Aspirant
2 way offsite replication
I'd like to use the built-in replication function in my readynas for replicating it to another offsite readynas.
Would that be possible for the offline readynas to replicate it self as well into the local one.
I'm perheps using the replication word wrongly... I'd be more than happy to just "replicate" some shares of each readynas, not the entire units.
Thanks for advice and sorry for confusion
- FramerVNETGEAR Employee Retired
Hi netghiro,
You may want to try using Rsync for this.
Please let me know if this is what you need.
FramerV wrote:
Hi netghiro,
It'd be better to use rsync over ssh: http://kb.netgear.com/app/answers/detail/a_id/29929
You can use this approach to back up some shares on ReadyNAS A to ReadyNAS B, and other shares on ReadyNAS B to ReadyNAS A.
It's not two-way sync though based on your earlier post I don't think you actually need that.
