julesg1
Aug 09, 2013Tutor
2-way rsync?
I have a new RD314 and an older NV+ NAS. I want to use the older NV+ as a remote backup NAS and use Rsync to accomplish this. However Rsync seems to work only in 1 direction. Is it possible to make th...
WarrenT
Apr 07, 2014Tutor
Hi, please clarify for me:
I would like only one way syncing using RSYNC or REPLICATE. From a new RN312 (OS6 which includes RSYNC) to an older Duo (which does not have RSYNC included). I wish to sync (once a day, after hours) the 10 Shares on my RN312 to the older Duo. I do not require any syncing from old Duo to the RN312. ie this is a one way process most times. Only if I must restore back from Duo to RN312, will I need a 'reverse' flow
Will this be possible? I do not wish to purchase a separate REPLICATE licence for the older Duo.
Thanks
Thanks
