julesg1
Aug 09, 2013Tutor
2-way rsync?
I have a new RD314 and an older NV+ NAS. I want to use the older NV+ as a remote backup NAS and use Rsync to accomplish this. However Rsync seems to work only in 1 direction. Is it possible to make th...
TeknoJnky
Apr 07, 2014Hero
if you have a sparc based duo, firmware 4.x, then it does not support replicate.
if both devices are on the same network, then rsync backup jobs should work fine, simply create an appropriate backup job.
to restore from the duo to the rn312, you would need to either reverse the existing backup jobs (swap source/destination) or create additional backup job(s) to pull the data from the duo to the rn12.
