julesg1
Aug 09, 2013Tutor
2-way rsync?
I have a new RD314 and an older NV+ NAS. I want to use the older NV+ as a remote backup NAS and use Rsync to accomplish this. However Rsync seems to work only in 1 direction. Is it possible to make th...
WarrenT
Apr 07, 2014Tutor
Hi, and thanks. The Duo is Sparc based with RAIDiator 4.1.13 and I do not plan to buy a separate REPLICATE licence for the old Duo.
However, it IS on the SAME LAN, so I interpret your comment to say that RSYNC (one way) backup from new RN312 (OS6) to old Duo (Sparc) will be able to work. Is that correct?
Many thanks
Many thanks
