julesg1
Aug 09, 2013Tutor
2-way rsync?
I have a new RD314 and an older NV+ NAS. I want to use the older NV+ as a remote backup NAS and use Rsync to accomplish this. However Rsync seems to work only in 1 direction. Is it possible to make th...
Apr 07, 2014Guru - Experienced User
You really only want one-way sync, with the ability to restore the source if it is damaged. Two-way sync would only be needed if you were using both NAS as primary storage, and wanted changes to either to be reflected on the other.
It is easy to reverse source/destination of the backup jobs.
Rsync from the RN312 to the Duo will work fine. (You can run the backup jobs from either NAS).
