julesg1
Aug 09, 2013Tutor
2-way rsync?
I have a new RD314 and an older NV+ NAS. I want to use the older NV+ as a remote backup NAS and use Rsync to accomplish this. However Rsync seems to work only in 1 direction. Is it possible to make th...
May 10, 2014Guru - Experienced User
I agree that it is often useful to set up 1-way backups with rsync (and other protocols). If you have some control over user behavior at both ends, you can also use these backup jobs to keep two folders in sync. Though this is not a true bi-directional sync, and if you aren't very careful it will not give you the results you want.
