julesg1
Aug 09, 2013Tutor
2-way rsync?
I have a new RD314 and an older NV+ NAS. I want to use the older NV+ as a remote backup NAS and use Rsync to accomplish this. However Rsync seems to work only in 1 direction. Is it possible to make th...
May 11, 2014Guru - Experienced User
I have two laptops (used for different employers), but would like to have some data sync'd between them. Both are backed up using image backup. Security is a concern for the unsynced data, so I'd need to assess whether non-synced data could leak.
