Javik
Oct 08, 2014Aspirant
2014: Lowest-cost consumer deduplication?
I've done a forum search to try to find the lowest-cost deduplication options, but this forum has been around a while, pulling up posts as far back as 2008. Is it possible that someone could post an u...
Oct 09, 2014Guru - Experienced User
Also, re-reading your original post, I am thinking you might not need full de-duplication. You are suggesting that a couple of files are changing, not that segments of a large file (like a database) are changing.
That suggests that incremental rsync backup to an RN100 series or RN300 series might serve. Only files that are changed are copied (but they are copied in their entirety). Older versions are easily retrieved using the OS6 snapshot feature. The snapshots give you a full view of the original folder at the time the snapshot was taken, but only require the disk space needed to store the files changed in the parent folder after the snapshot was made (thanks to btrfs).
