bullfrog1
Apr 09, 2013Tutor
2100 / 2120 performance Figures
Hi As far as I can tell the 2100 range is now EOL although I can't find any official statement to this effect. Is there a page for the 2120 which similar to this one which is for the 2100 - http...
bullfrog1
Apr 09, 2013Tutor
Hi
Thanks for your help and the directly sent info. I believe I can use the existing add-on mechanism that is built into other arm based readynas products. Netgear use it to turn on remote support. I won't know if thats an option till i get a unit. That seems to be the next hurdle. Shortage of supply of 2120's.
Thanks again
Bullfrog
Thanks again
Bullfrog
