Papagaiou
Aug 30, 2012Aspirant
2nd LAN for Readynas Ultra
Hello, I searched the forums without a clear answer. The nas is connected to a 100Mb router were a single computer is also attached. This router is also connected to a GB wireless router. I wou...
mdgm-ntgr
Aug 30, 2012NETGEAR Employee Retired
The second ethernet port would be for connecting to a separate network or making a second connection to the same network as the other port.
If you are comfortable with shell commands you could try and do something via SSH I guess though this wouldn't be recommended.
Best thing to do would be to replace the router with one that does gigabit or put a gigabit switch in between the router and the NAS. You could connect both the NAS and the PC to the gigabit switch and the switch to the router. You'd then get gigabit speeds between your PC and the NAS.
