rtrogemann
Jul 27, 2016Aspirant
2TB to 4TB HDD Replacement: Data Degraded?
Hi, I had 4 Harddisks in the ReayNAS-314: 4TB/4TB/2TB/2TB. Then I've exchanged the first 2TB Harddisk and waited for a complete resync. (Now 4TB/4TB/3TB/2TB) After round about 24h syncing was compl...
mdgm-ntgr
Jul 27, 2016NETGEAR Employee Retired
Can you send in your logs (see the sending logs link in my sig)?
Is that a typo or did you really replace a 2TB disk with a 3TB disk?
rtrogemann
Hi, I've sent the log. Yes it's no typo. ;-) I know, it's not so much difference, but I had two 3TB Harddisks unused.
- StephenBJul 27, 2016Guru - Experienced User
Actually there will be no space increase unless you do a factory reset.
You can't add an intermediate size disk to an array.
- mdgm-ntgrJul 27, 2016NETGEAR Employee Retired
Yes.
Backing up and doing a factory reset (wipes all data, settings, everything) and restoring from backup is the way forward here.
Looking at the logs one of the 3TB disks isn't being used by the data volume.
When sending the logs in in future please follow the instructions and include a link to your thread in the body of the email.
