IanSav
Nov 30, 2010Apprentice
4.1.7 Slow To Respond To SMB Network Discovery...
Hi,
Since upgrading my DUO to 4.1.7 I have noticed that the DUO is *very* slow to respond SMB/SAMBA network share enumeration requests. It may take up to about a minute for the DUO to provide its list of shares. The problem happens *every* time the DUO is asked to list its shares and not just for the first request. This was not an issue under 4.1.6. (I never ran any of the betas and upgraded from 4.1.6 production directly to 4.1.7 production. There were no obvious issues with the upgrade.)
On a client PC this results in about a minute of waiting before the DUO responds with a share list. This is long but not particularly problematic. On the other hand, to my media players this response is *so* long that the media player times out and is no longer able to find the DUO. This is *very* problematic.
This is only happening on my DUO with 4.1.7. The same DUO with 4.1.6 was fine and my NVX with 4.2.15 is also fine.
Is it possible to get a patch to repair this issue? Is there anything I can do to restore the previously snappy performance? Is it safe/possible to revert to 4.1.6?
Ian.
Ian.
- IanSavApprenticeHi Siigna,
siigna wrote: That would work. PM me your contact info and I'll get in touch with you.
Done!
Ian. - fetferAspirantHi Siigna,
I also have this issue, I have sent an email via the Post logs email address with a copy of my logs.
Lets hope they help you do an RCA on this issue, if you need anything more let me know.
rgds
Fetfer - WSJTutor
siigna wrote: Actually if anyone here that can replicate the issue has root access that'd be great. If you can increase the logging for samba and try connecting to the share, then send me the resulting logs that might be helpful here.
I'll do so. - siignaNETGEAR Employee RetiredBeen a bit busy here but haven't forgotten about this. fetfer: I have your logs. WSJ: I have your case still and if you have any other logs to add that'd be great. IanSav: I'll keep your contact info in mind here, let me sort through fetfer's data and WSJ's when I get it and if I need more I'll let you know as well.
- WSJTutor
siigna wrote: WSJ: I have your case still and if you have any other logs to add that'd be great
I've send the file (/var/log/samba/log.smbd)(mail title: "Case 15187681 - Attn: siigna").
If you need additional information, just let me know. - BadBradAspirantThis SMB network discovery problem is the sole reason I have not upgraded to this version on my Duo. From reading the posts it sounds that I am pretty much guaranteed that I will have this problem.
Does anyone know what the status is on this issue? I feel response from netgear has been extremely slow. I see in the recent posts that some of the logs have finally been obtained by them, but I have not seen any followup discussion by them in this forum.
Any opinions on whether I should upgrade? My current thoughts are no and wait until this is fixed. However, it is taking forever to get a 4.1.8 version where this is fixed and I fear that since the duo is now an older product, there may be no future updates. - MilhouseTutorDitto. I'm giving 4.1.7 the swerve until this is resolved, the other benefits of 4.1.7 are just not worth the risk of getting hit by this SMB problem.
Do you have any updates on this issue?
Ian. - vwmooseAspirantI've been experiencing this problem as well, is there any information yet on a fix?
- siignaNETGEAR Employee Retired@IanSav and @WSJ: Any chance you can send me over a copy of the system logs as well?
