Stroker
Sep 21, 2014Aspirant
404 file not found
When trying to reach my readynas nv+ from my external ip (done all after the instructio here how to turn on the webdav) I just got the pink side say 404 not found and a acme http shit something under...
Sep 21, 2014Guru - Experienced User
Probably the belkin is using 443 for remote administration.
Try configuring the NAS to use an alternative http port (say 50443), and forward that port. Then access the share using https://externalip:50443/sharename.
If all you are doing is uploading an ics file, then you don't need webdav (though you can of course use it).
Also, you probably will want a ddns service, since your external IP will change w/o notice. noip still offers a free one.
I suggest taking the NAS out of the DMZ though.
