Stroker
Sep 21, 2014Aspirant
404 file not found
When trying to reach my readynas nv+ from my external ip (done all after the instructio here how to turn on the webdav) I just got the pink side say 404 not found and a acme http shit something under...
Sep 22, 2014Guru - Experienced User
Does it work on your local lan (using the NAS internal address, but the secondary port)?
Did you check that the port you used was open using http://www.canyouseeme.org/?
Knowing those two pieces of information will help isolate the issue to your NAS, your router, or your ISP.
