nsne
Dec 10, 2015Virtuoso
4TB to 6TB HDD Replacement: Data Degraded?
I'm upgrading the storage on my RN314. After installing a new 6TB HDD in an empty slot two days ago, I've got the following drives in the following bays: 1. 4TB 2. 4TB 3. 4TB 4. 6TB Per th...
- Dec 10, 2015
The volume is degraded because you removed the disk. What that means is that the volume can not recover from another disk failure. That is completely expected behaviour. XRAID with single redundancy can only protect against loss of one disk - and when you removed the drive, you lost one.
When you insert the new disk, it will add it to array, and redundancy will be restored after the resync. After that, the NAS should prompt you to reboot. After the reboot, the volume should expand by 2 TB.
The process will take a while - I don't have a good estimate, but my guess is 12 hours to restore redundancy. Expansion will be quicker.
Dec 10, 2015Guru - Experienced User
- nsneDec 10, 2015Virtuoso
Rock on. That's exactly what I wanted to know. Thanks so much for your clear and speedy reply.
