networkn
Dec 09, 2011Aspirant
5.6KB/s Speeds from Duo (Gigabit Wired)
Hi There! I am really struggling to contain my temper. I decided after struggling with my Duo for 2 Years to replace it with a Ultra2 Plus, but before that I need to get the data from it, somewhere...
networkn
Hi.
Ok well I have sorted of sorted the issue. I was daisy chained to another netgear 8 port switch, and if I connect to THAT switch and don't daisy chain the problem is resolved I think. I am getting 21-30MB/s right now.
Neither switch is faulty (as mentioned I have replaced the other before with no change). Why would the NAS care about DC
