networkn
Dec 09, 2011Aspirant
5.6KB/s Speeds from Duo (Gigabit Wired)
Hi There! I am really struggling to contain my temper. I decided after struggling with my Duo for 2 Years to replace it with a Ultra2 Plus, but before that I need to get the data from it, somewhere...
Dec 10, 2011Guru - Experienced User
I am wondering if the switches all have 802.1x flow control enabled. If not, then possibly you are running out of buffering in the switch.
