fabNAS
Sep 20, 2014Aspirant
6.1.9 roll back to 6.1.8 possible?
Hi - It's couple of months that I have ReadyNas312 and the main reasons i bought it were the possibility to install Plex and Amule, they both worked fine until the firmware upgraded to the version 6.1...
fabNAS
mdgm wrote: Have you tried installing the amule add-on over the top of itself via the upload button on the Dashboard?
Hi, thanks for your help.
My knowledge of NAS and in particular of my ReadyNas is almost null, the only thing I've done is remove it from APPS section, deleted the amule folder and re-install it from the APPS section. And it did not work.
I see the Upload button but I guess that means i need first to download in my pc the amule file which i don't know where to find them.
