grahamu59
Oct 10, 2015Tutor
6.4.0 102 - No scheduled power on.
My 102 powers down and up on a schedule, this has been the case without issue for a long time. Since upgradig to 6.4.0 (from 6.2.5) it no longer comes up correctly. I find the power light flashing an...
vandermerwe
Oct 11, 2015Master
Does it power down completely on schedule?
Do,you have any apps running?
Have you scheduled any volume maintenance that may have been running at shutdown?
Are the disks smart stats normal?
- grahamu59Oct 11, 2015Tutor
vandermerwe wrote:Does it power down completely on schedule?
It certainly goes offline at the correct time. I'll check next time I'm around at night that it is completely off.
Bzeetr6 and AV plus are installed and cannot be stopped in the GUI so are 'running' but not busy. Other apps are stopped.
All my maintainance runs in the first few days of each month so was completed a few days prior to the upgrade.
SMART is all normal, yes.
I can now say it's the shutdown that is the issue - goes to a power light flashing state only and does not shut down. It's not startup that's the problem.
I did notice this in the Services.conf log :
ENABLE_POWERON_TIMER_SUPPORT=0
That surprised me - is it right?
- vandermerweOct 12, 2015Master
This is often due to a process stopping the shutdown.
Can you disable those 2 apps?
You are sure there are no running backup jobs?
