grahamu59
Oct 11, 2015Tutor
6.4.0 102 - No scheduled power on.
My 102 powers down and up on a schedule, this has been the case without issue for a long time. Since upgradig to 6.4.0 (from 6.2.5) it no longer comes up correctly. I find the power light flashing an...
grahamu59
Oct 12, 2015Tutor
I can now say it's the shutdown that is the issue - goes to a power light flashing state only and does not shut down. It's not startup that's the problem.
I did notice this in the Services.conf log :
ENABLE_POWERON_TIMER_SUPPORT=0
That surprised me - is it right?
vandermerwe
Oct 12, 2015Master
This is often due to a process stopping the shutdown.
Can you disable those 2 apps?
You are sure there are no running backup jobs?
- grahamu59Oct 15, 2015Tutor
Have now tried that - no change.
I can also say now that shutdown by any method fails. (Power button, ssh shutdown -h-P or admin page). Never had this issue before this firmware.Seems to be the same issue as
- vandermerweOct 16, 2015Master
I would contact support, sounds like someone will need to remotely access your device to see what is stopping shutdown
- YeZOct 19, 2015NETGEAR Expert
Instead of contacting support, you can send email to readycloud@netgear.com so we can help out too.
