fragglerok
Nov 11, 2015Aspirant
6.4 is a total disater
Wish id neber upgarded to 6.4 on readynas 104, its been a total disater. The sytem will not stay up for more than 2 days without locking up requiring a hard reboot. Its never actually stayed up for l...
mdgm-ntgr
Nov 11, 2015NETGEAR Employee Retired
Please send in your logs (see the Sending Logs link in my sig).
- mdgm-ntgrNov 12, 2015NETGEAR Employee Retired
You are running the 3.00.6 version of the Transmission app which has the potential to cause problems. There was a new version 3.00.8 released quite a long time ago now.
What apps do you have installed?
Do you have a backup of your data? - fragglerokNov 13, 2015Aspirant
ive updated to the newer transmisssion, which if anything has made it worse, i also have sickbeard tpb
no backup of the data, and its to large to backup to the drives i have
- StephenBNov 13, 2015Guru - Experienced User
Truthfully, you should get bigger (or more drives) and back up the NAS.
Otherwise you will lose your data at some point - just a matter of time. RAID isn't enough to keep it safe.
