Homyakchik's avatar
Homyakchik
C3700 Want to totally disable Readyshare
Howdy all
Recently purchased the C3700 to replace the rental I'd been paying Comcast for. After some initial hiccups (all at Comcast's end), it's up and running and seems to be doing nicely. Little learning curve setting up access control and DHCP after my last router (a Linksys of some make and model), but it all works.
(Although I'll say right now that having the modem's password displayed in large, friendly letters on an attention-getting billboard when you hit the first page of the modem's internals is more than a little retarded. Now I have to make sure I'm the only one in the room if I need to even log onto the modem to look at something.)
The modem comes with a feature called Readyshare, presumably if I want to hook up a USB stick or device. I DON'T. I prefer network shares to shares hanging off the modem. I'd like to disable it, but the only radio button on the Readyshare page is Enabled and I can't un-check that.
How do I disable Readyshare? Don't need it, don't want it, and it's just an extra space-eating entry in the network location list.
Did google this. Found nothing. Hoping there's an answer here that's simply not anywhere to be found in the modem's setup pages.
Thanks!
Davey
  • How about going to ADVANCED > USB Storage > Advanced Settings and unchecking all of the checkboxes?
    You can also go to ADVANCED > Advanced Setup > USB Settings and disable the USB port.
