fragglerok
Nov 11, 2015Aspirant
6.4 is a total disater
Wish id neber upgarded to 6.4 on readynas 104, its been a total disater. The sytem will not stay up for more than 2 days without locking up requiring a hard reboot. Its never actually stayed up for l...
fragglerok
Nov 13, 2015Aspirant
ive updated to the newer transmisssion, which if anything has made it worse, i also have sickbeard tpb
fragglerok
no backup of the data, and its to large to backup to the drives i have
- StephenBNov 13, 2015Guru - Experienced User
Truthfully, you should get bigger (or more drives) and back up the NAS.
Otherwise you will lose your data at some point - just a matter of time. RAID isn't enough to keep it safe.
- fragglerokNov 13, 2015Aspirant
so your answer to bad firmware is for me to get another nas an another 16tb , hardly a good anser
fragglerok wrote:
so your answer to bad firmware is for me to get another nas an another 16tb.
No. I'm just saying that if you don't make backups of your data, you will eventually lose it - perhaps a device failure, nearby lightning strike, disaster, or theft. You can make them with USB drives, a cloud backup service like Crashplan, another NAS, ...
It doesn't matter what the primary device is, the only way to protect your data is to have independent copies of it.
Netgear (IMO) clearly released 6.4 too soon. But protecting your data is ultimately your job, not their's. And if you had a backup, you'd have more options now.
