Vinfo1
Dec 05, 2016Aspirant
6.6.0 - System Hangs during backup to USB device
Firmware 6.6.0
I wanted to backup my photo's to my USB drive. The USB-drive is already used for a former backup of the photo's, and I want to add the latest photo's to my USB-backup. a so called incremental backup
As soon as started the backup, I get a system hang: the front panel shows an error on row 1: __percpu_counter
and on row 2: _add+3c
after the reboot, the readynas is working properly.
No entries in any logbook.
I use a 500GB Seagate Pipeline HD in a Sharkoon docking station of yhe front USB-port. The HD is formatted in NTSC format.
The question now is: what's going wrong?
- mdgm-ntgrNETGEAR Employee Retired
That error could come from anywhere.
Can you send in your logs (see the Sending Logs link in my sig)?
- Vinfo1Aspirant
I have sent the system logs.
fyi. I tried to make a new backup, exactly according to the description of :
http://kb.netgear.com/29654/How-do-I-back-up-data-from-my-ReadyNAS-OS-6-system-to-a-USB-disk
Also format the disk in Ext4. So, I had an empty disk.
The backup task did start succesfully, but after a short while, the same system hang occurs. After booting the NAS, a resync started.
- JennCNETGEAR Employee Retired
Hello Vinfo1,
Thanks for sending. Let's wait for results. I hope you have included the of this thread to the email.
