Justinian
Aug 21, 2017Aspirant
6.8.0 Kernel warning
Hello all,
There is something wrong in the was the 6.8.0 has been compiled. 6.7.5 has no such issues. Since this is a problem in the BTRFS module I believe this should be fixed asap in order to...
Aug 21, 2017Guru - Experienced User
Which NAS model?
I'm not seeing this on the RN52x, so it must be arm-specific.
Justinian
Aug 22, 2017Aspirant
Indeed it might be ARM related, the models are RN102 and RN202, both are showing the same warnings.
- mdgm-ntgrAug 23, 2017NETGEAR Employee Retired
This issue is neither new nor common, but the message is new. The error has no effect on data safety or anything related to that.
In the next firmware release 6.8.1 you should no longer see this message.
- JustinianAug 25, 2017Aspirant
I see there is a 6.8.1 beta 1 already in testing. Is there any chance of getting an upgrade linux-image package for this ? I see there is a:
Package: readynasos
Architecture: armel
Version: 6.8.0+2
but the kernel dependency is still the same Pre-Depends: linux-image (= 4.4.79-60800035)
I've just tested the beta 1 release and the warning is still there:
[ 1672.662755] ------------[ cut here ]------------ [ 1672.662800] WARNING: CPU: 0 PID: 4051 at fs/btrfs/qgroup.c:2480 btrfs_qgroup_free_refroot+0x180/0x1b8() [ 1672.662808] Modules linked in: vpd(PO) [ 1672.662828] CPU: 0 PID: 4051 Comm: kworker/u2:9 Tainted: P O 4.4.83.armada.1 #1 [ 1672.662835] Hardware name: Marvell Armada 370/XP (Device Tree) [ 1672.662854] Workqueue: btrfs-extent-refs btrfs_extent_refs_helper [ 1672.662893] [<c0015f24>] (unwind_backtrace) from [<c00120dc>] (show_stack+0x10/0x18) [ 1672.662914] [<c00120dc>] (show_stack) from [<c0392ca0>] (dump_stack+0x78/0x9c) [ 1672.662941] [<c0392ca0>] (dump_stack) from [<c0024928>] (warn_slowpath_common+0x74/0xac) [ 1672.662956] [<c0024928>] (warn_slowpath_common) from [<c002497c>] (warn_slowpath_null+0x1c/0x28) [ 1672.662969] [<c002497c>] (warn_slowpath_null) from [<c0318db8>] (btrfs_qgroup_free_refroot+0x180/0x1b8) [ 1672.662992] [<c0318db8>] (btrfs_qgroup_free_refroot) from [<c028abf4>] (__btrfs_run_delayed_refs+0x328/0x113c) [ 1672.663009] [<c028abf4>] (__btrfs_run_delayed_refs) from [<c02918c0>] (btrfs_run_delayed_refs+0x60/0x2b0) [ 1672.663023] [<c02918c0>] (btrfs_run_delayed_refs) from [<c0291f38>] (delayed_ref_async_start+0xa4/0xb0) [ 1672.663037] [<c0291f38>] (delayed_ref_async_start) from [<c02dbf38>] (normal_work_helper+0x84/0x1a4) [ 1672.663057] [<c02dbf38>] (normal_work_helper) from [<c0037fb4>] (process_one_work+0x11c/0x334) [ 1672.663070] [<c0037fb4>] (process_one_work) from [<c0038238>] (worker_thread+0x34/0x474) [ 1672.663084] [<c0038238>] (worker_thread) from [<c003d2cc>] (kthread+0x104/0x124) [ 1672.663097] [<c003d2cc>] (kthread) from [<c000f568>] (ret_from_fork+0x14/0x2c) [ 1672.663105] ---[ end trace e53b4163435df1aa ]--- [ 1672.663118] BTRFS warning (device md127): qgroup 1860 reserved space underflow, have: 4096, to free: 12288 [ 1672.663197] ------------[ cut here ]------------
