OxfordeBooks
Oct 13, 2026Aspirant
A complete mess after RAID failure...
Okay, I'm very confused and would really appreciate some help from the community here. This is going to be a long post I'm afraid but I thought it good to write as much detail as I can so that perha...
OxfordeBooks
AH! Now that makes a lot of sense! Thanks SO much for a quick response. And also SO glad the solution seems pretty simple.
Giving this a try now. So far, I'm now able to see my WORK SHARE in all the proper places, incl the web interface. Let's see how the backup fares...
Oct 13, 2026Guru - Experienced User
OxfordeBooks wrote:AH! Now that makes a lot of sense!
You were responding to an AI-generated post. I suggest you read my reply which outlines next steps.
Some of the steps in the earlier post were missing, and since there is at least one unexplained issue I recommend doing the reset and starting over.
- OxfordeBooksOct 13, 2026Aspirant
LOL, I kinda guessed it was either AI or a copy-paste! :)
I'm going to make sure I've got a full, manual backup of everything first before I try a reset... see you in a couple of days... ugh.
Thanks for the insight though.
