brentrl
Aug 19, 2014Aspirant
a File explorer for OS6
Hi, I have recently upgraded to OS6 from 4.x.x. Under version 4 I had a file explorer app PHPexplorer I think that was a handy way to move and rename and delete file on the array w\o working throu...
xeltros
Aug 19, 2014Apprentice
You are able to browse directly on the interface under shares then click on one and select browse.
You could also look into ajax explorer or pydio file explorer in the available applications (directly under applications tab).
