brentrl
Aug 19, 2014Aspirant
a File explorer for OS6
Hi, I have recently upgraded to OS6 from 4.x.x. Under version 4 I had a file explorer app PHPexplorer I think that was a handy way to move and rename and delete file on the array w\o working throu...
brentrl
Aug 20, 2014Aspirant
The browse function is fine for the files that are in shares, however not everything on my NAS is in a share. What if I need to access a user's home folder ? I know I could create a share for that folder and go from there but the fact is for the I don't like using shares as removing shares removes the actual folder AND the data...really dumb design. And I don't like the idea of having a bunch of typically unused shares on the system. Shares should not be actual folders but pointers, permission containers if you will. I can connect to the C volume via SMB as admin and generally do what I want but files sometimes get 'locked' and widows explorer won't allow me to edit files. So I am looking for a root access file manager, I know this could all be done via a shell but I prefer to work in a visual environment. I have looked into pydio and ajax explorer but don't know how to configure them to show my root file system.
Thanks
Thanks
