dox1000
Sep 01, 2013Aspirant
access denied Issues
OK, OK have been reading posts both here and on the windows boards trying to figure out permissions for days. I have had many a NAS, but the current one is a Pro. I am using Windows 7 Pro 64 bit a...
Sep 03, 2013Guru - Experienced User
I was responding to your comment that you couldn't set the owner to Dox100 in frontview. You can only set the owner to a NAS user account.
dox1000 wrote: 1. I am going to assume that you mean that in order to make windows give permissions to Dox100(who is defined as the admin login user on the desktop I use), there needs to be a NAS user with the name dox1000, and I have to be logged in as that person. My question then becomes why would I all of a sudden need such an account to have write/delete permissions when I never did before? I know it is not optimal, but how would I need to correct this problem assuming I was logged in as admin on the NAS/Mapped Network Drive?
I have noticed with 4.2.24 firmware that when I drop/drag files a read-only file into a share, that the read-only attribute is preserved even if the CIFS configuration is set to read/write and "Automatically set permissions on new files and folders" and "Do not allow ACL changes to be more restrictive than this" are checked. I don't recall seeing this before, and was wondering if anyone else is seeing this.
