CABird_UK
Jul 22, 2016Tutor
Access external connected USB drive NAS 104
ReadyNas 104 - Fireware 6.5.1 I've connected USB drive. Is there a way to access the drive like a i-SCSI drive i.e. upload and view drive contents without having to access USB drive via brows...
- Aug 05, 2016
Finally found the solution I was looking for. Thanks to all, who assisted me, to find a solution.
Hopchen
Jul 23, 2016Prodigy
You will be able to access the USB over SMB,NFS,AFP, etc. (just like any other share on your NAS). If you go to the GUI of the NAS, make sure the network service (typically SMB) is enabled on the USB device. Hereafter, you should be able to browse to it (using Windows explorer):
\\ipofyournas\nameoftheusb
You can see the name of the USB in the GUI. It is called something like USB_HDD1.
