CABird_UK
Jul 22, 2016Tutor
Access external connected USB drive NAS 104
ReadyNas 104 - Fireware 6.5.1 I've connected USB drive. Is there a way to access the drive like a i-SCSI drive i.e. upload and view drive contents without having to access USB drive via brows...
- Aug 05, 2016
Finally found the solution I was looking for. Thanks to all, who assisted me, to find a solution.
Aug 03, 2016Guru - Experienced User
CABird_UK wrote:
I can assure NAS GUI, 'Hide this folder' option hasn't been ticked.
Though that was asked early on, it's actually not relevant when you are accessing the share explicitly. \\nasname\folder or net use t: \\nasname\folder will work even if the folder is hidden.
Let's step back a moment. Can you access the shares on the NAS that are on the data volume? Or is this specific to USB drives?
Also, what firmware are you running?
CABird_UK
Aug 03, 2016Tutor
Hello
\\nasname\folder regardless of whether IP or nasname is used, access is denied.
Using a browser I can access the USB drive, create folders, add files. What I cannot do is use Windows Explorer to access the drive. Using ReadyCloud I have found a mentod to access the USB Drive.
Using my Netgear ReadyNas AV+ I'm able to create a drive share. Doing this allows me to use Windows Explorer to add, create folders and new files etc. In other words I can directly access the drive without having to use any additional software. This is my preferred way to access a drive connected to NAS as I do not need to install ReadyCloud software on other devices on the Network.
Firmware 6.5.1
Thank you for your help and assistance to resolve this issue.
- StephenBAug 03, 2016Guru - Experienced User
So
-you can't access anything on the RN104 with windows explorer, this is not specific to the USB drive.
-but the same PC can access your NV+ with windows explorer
-the PC is running windows 10 enterprise
-both the NV+ and the RN104 have SMB enabled, and the NAS shares on both machines have guest access enabled.
Let me know if I am getting this wrong.
Assuming I'm not -
-are the two NAS connected to the network the same way (that is, through the same switch/router)?
-does the PC have any internet security software installed?
-are both NAS set to the same windows workgroup?
-does the computer name or the username on the PC match an account or a share name on the NAS?
-does the behavior change if you uninstall ReadyCloud?
- CABird_UKAug 03, 2016Tutor
Hello
First section, YES to all below.
Second section
-are the two NAS connected to the network the same way (that is, through the same switch/router)? Yes switch.
-does the PC have any internet security software installed? Use Windows Defender.
-are both NAS set to the same windows workgroup? Yes.
-does the computer name or the username on the PC match an account or a share name on the NAS? NAS login differs to Win 10 computer and user names.
-does the behavior change if you uninstall ReadyCloud? No
CABird_UK wrote:
Hello
Ok, but does either the PC logon or PC name happen to match the name of a public share on the NAS?
Does either the PC logon or PC name happen to match the name of a public share on the NAS? NO - NAS public share applied defaults see below.
Windows cannot access \\NAS-E6-4B-B2
error code 0x80070035USB Drive persmissions>AnonymousExternal Properties>Name USB-HDD_2
External Description HM160HCNetwork Access - Protocols SMB NFS AFP FTP
Network Access - slider ON
Network Access>Security Everyone Read/Write
Network Access>admin Read/WriteThere is a name using an email address with read/write that does match One Drive log on. It has a icon person with key, cloud surround.Hosts>IP Address (NAS IP address used)
Hosts>DFS
Hosts>Advanced>Hide this folder NO TICKThree users that cannot be set to read/write - read only tick boxes available.File Access>Security The feature is not supported for the selected share/device - StephenBAug 03, 2016Guru - Experienced User
Try enabling guest access on the USB share and see if anything changes.
Do you have public shares on the data volume? If so, are you trying them also?
Not possible. File Access>Security MESSAGE READS 'The feature is not supported for the selected share/device'
Media Devices>Pictures or Videos or Music folders can access.
Documents folder protocol SMB AFP, PERMISSIONS Anonymous - File Access>Security set to GUEST available options (root, admin, guest, users)
What you are calling folders are public shares (and are shown on the web ui "shares" page, etc). If you can access them with windows explorer then your earlier answer (quoted below) was wrong.
CABird_UK wrote:
Hello
-you can't access anything on the RN104 with windows explorer, this is not specific to the USB drive....
So please - is your problem specific to the USB drive, or is it a general problem with accessing the RN104 shares from windows explorer.
- CABird_UKAug 04, 2016Tutor
What you are calling folders are public shares (and are shown on the web ui "shares" page, etc)?
Open Explorer, use IP address to log onto NAS drive, under share tab there are folders for example Documents, Videos, Music etc.
I cannot open This PC or Windows explorer and see these folders listed. Navigate to Network, I see other computers on the Network as well as devices such as NAS-E6-4B-B2 (NAS drive) I click on this and Windows cannot access \\NAS-E6-4B-B2 consequently I cannot navigate to folders.
So please - is your problem specific to the USB drive, or is it a general problem with accessing the RN104 shares from windows explorer?
Let me be absolutely clear. NO access to USB drive (not listed in This PC or Windows Explorer as an available drive. NAS shares cannot be accessed for example Doucments.
Hopefully the below images migh help.
- StephenBAug 04, 2016Guru - Experienced User
Thanks, that helps.
This statement
was making me think that the NAS internal shares were accessible from windows explorer.
One challenge here is that you are centering your vocabulary around windows explorer, and I am centering mine around the NAS / web UI. Just knowing that helps me.
- bedlam1Aug 04, 2016Prodigy
Just an observation here (I am a Pro 4 not a 104 user), I hope I am not being dumb, but how have 4 USB Drives been attached externally?
Or can a USB hub be used with Readynas'?
Back on point....
Ignoring USB for now.
\\192.168.1.65
\\NAS-E6-4B-B2
both fail from explorer
net use t: \\192.168.1.65\data /user:admin password
net use t: \\NAS-E6-4B-B2\data /user:admin password
both fail from cmd
No shares on the NAS match the PC username or the PC hostname
The PC and the NAS are in the same workgroup.
No internet security software on the PC (just windows defender)
PC network is configured as private.
The NAS can be reached through http (web admin ui)
And DLNA (media devices) works too.
Does this sum it up?
If so, its not about connectivity, and its not about credentials. But it isn't clear what is.
Oh .....pardon me for being a distraction :manfrustrated:
Ok thanks.....am confused how 4 are shown (but I am no expert)
Hello Stephen B
Three USB drives but one has been partitioned into three.
Hope that helps
- CABird_UKAug 05, 2016Tutor
- bedlam1Aug 05, 2016Prodigy
Cannot open/see the image posted
I don't know why given I used the exact same file format previously.
I can see the image now, must be vetted.
Can you describe what you found/did to resolve your problem for the benefit of others? - CABird_UKAug 05, 2016Tutor
Resolved thank you.
Other users in my network simply won't learn how to use Ready Cloud but will use a Windows share.
Really appreicate the assistance in resolving this issue.
- StephenBAug 05, 2016Guru - Experienced User
If 5.236.91.16 is the IP address, then I think you are accessing the NAS through the ReadyCloud VPN, and not directly.
You might want to check your transfer speeds by reading/writing a large file to the NAS and looking at the speed graph windows-10 gives you (or simply timing the transfer with a watch).
Thanks, other users generally don't work with large files nevertheless I will run the tests as I know users will complain if they think they are waiting to long.
