CABird_UK
Jul 22, 2016Tutor
Access external connected USB drive NAS 104
ReadyNas 104 - Fireware 6.5.1 I've connected USB drive. Is there a way to access the drive like a i-SCSI drive i.e. upload and view drive contents without having to access USB drive via brows...
- Aug 05, 2016
Finally found the solution I was looking for. Thanks to all, who assisted me, to find a solution.
CABird_UK
Aug 03, 2016Tutor
Hello
First section, YES to all below.
-you can't access anything on the RN104 with windows explorer, this is not specific to the USB drive.
-but the same PC can access your NV+ with windows explorer
-the PC is running windows 10 enterprise
-both the NV+ and the RN104 have SMB enabled, and the NAS shares on both machines have guest access enabled.
Second section
-are the two NAS connected to the network the same way (that is, through the same switch/router)? Yes switch.
-does the PC have any internet security software installed? Use Windows Defender.
-are both NAS set to the same windows workgroup? Yes.
-does the computer name or the username on the PC match an account or a share name on the NAS? NAS login differs to Win 10 computer and user names.
-does the behavior change if you uninstall ReadyCloud? No
Aug 03, 2016Guru - Experienced User
CABird_UK wrote:
Hello
Ok, but does either the PC logon or PC name happen to match the name of a public share on the NAS?
- CABird_UKAug 03, 2016Tutor
Does either the PC logon or PC name happen to match the name of a public share on the NAS? NO - NAS public share applied defaults see below.
Windows cannot access \\NAS-E6-4B-B2
error code 0x80070035USB Drive persmissions>AnonymousExternal Properties>Name USB-HDD_2
External Description HM160HCNetwork Access - Protocols SMB NFS AFP FTP
Network Access - slider ON
Network Access>Security Everyone Read/Write
Network Access>admin Read/WriteThere is a name using an email address with read/write that does match One Drive log on. It has a icon person with key, cloud surround.Hosts>IP Address (NAS IP address used)
Hosts>DFS
Hosts>Advanced>Hide this folder NO TICKThree users that cannot be set to read/write - read only tick boxes available.File Access>Security The feature is not supported for the selected share/device - StephenBAug 03, 2016Guru - Experienced User
Try enabling guest access on the USB share and see if anything changes.
Do you have public shares on the data volume? If so, are you trying them also?
Not possible. File Access>Security MESSAGE READS 'The feature is not supported for the selected share/device'
Media Devices>Pictures or Videos or Music folders can access.
Documents folder protocol SMB AFP, PERMISSIONS Anonymous - File Access>Security set to GUEST available options (root, admin, guest, users)
