CABird_UK
Jul 22, 2016Tutor
Access external connected USB drive NAS 104
ReadyNas 104 - Fireware 6.5.1 I've connected USB drive. Is there a way to access the drive like a i-SCSI drive i.e. upload and view drive contents without having to access USB drive via brows...
- Aug 05, 2016
Finally found the solution I was looking for. Thanks to all, who assisted me, to find a solution.
Aug 04, 2016Guru - Experienced User
bedlam1 wrote:
Oh .....pardon me for being a distraction :manfrustrated:
The "back on point" was aimed at myself not you (our posts crossed).
The RN104 only has three USB ports - it would good to know what's connected and how.
CABird_UK
Aug 05, 2016Tutor
- bedlam1Aug 05, 2016Prodigy
Cannot open/see the image posted
- CABird_UKAug 05, 2016Tutor
I don't know why given I used the exact same file format previously.
I can see the image now, must be vetted.
Can you describe what you found/did to resolve your problem for the benefit of others? - CABird_UKAug 05, 2016Tutor
Resolved thank you.
Other users in my network simply won't learn how to use Ready Cloud but will use a Windows share.
Really appreicate the assistance in resolving this issue.
- StephenBAug 05, 2016Guru - Experienced User
If 5.236.91.16 is the IP address, then I think you are accessing the NAS through the ReadyCloud VPN, and not directly.
You might want to check your transfer speeds by reading/writing a large file to the NAS and looking at the speed graph windows-10 gives you (or simply timing the transfer with a watch).
Thanks, other users generally don't work with large files nevertheless I will run the tests as I know users will complain if they think they are waiting to long.
