indukwe
Aug 25, 2014Aspirant
Access issues after Firmware upgrade
Hi Everyone, I just upgraded the firmware on our ReadyNAS 1500 to RAIDiator 4.2.26. Immediately after the firmware upgrade, all users folders could not be accessed anymore. I checked the permissi...
vandermerwe
Aug 25, 2014Master
An OS reinstall does not delete files.
Make sure you don't do a factory default, which does wipe the disks.
Did you reset the permissions - also on the advanced tab where you set owner and group for the share?
