indukwe
Aug 25, 2014Aspirant
Access issues after Firmware upgrade
Hi Everyone, I just upgraded the firmware on our ReadyNAS 1500 to RAIDiator 4.2.26. Immediately after the firmware upgrade, all users folders could not be accessed anymore. I checked the permissi...
Aug 25, 2014Guru - Experienced User
Though if you can access the NAS as admin, it would be good to back up the data before you do the OS reinstall.
vandermerwe wrote: An OS reinstall does not delete files.
Make sure you don't do a factory default, which does wipe the disks.
The OS reinstall is non-destructive, but Murphy does sometimes rear up, and bite you...
