ukbobboy
Feb 08, 2016Luminary
Accessing My Plex Media Database, on my RN Duo V2.0, by Using My Browser
Dear Forum Members, especially those that use Plex (PMS) Up until 2 weeks ago, I could access my Plex database, to update and maintain my various entertainment media files, using my browsers. Un...
- Feb 08, 2016
You should still be able to manage the server from https://plex.tv
Assuming the default port (32400): http://nasipaddress:32400/web/index.html should also work.
Feb 08, 2016Guru - Experienced User
mdgm-ntgr
Feb 09, 2016NETGEAR Employee Retired
Also you can access this page via the Dashboard and would be able to get the URL to directly access it that way too.
- ukbobboyFeb 09, 2016Luminary
Dear StephenB & mdgm
Both of you have given me exactly what I was looking for, and as you can imagine, after my system crash my mind is swimming with all the facilities and applications I need to get back in order to make my computer usage a pleasant experience again. But as you can guess some facilities get used so often that it can be forgotten how they actually work.
This was the case with me, I remembered the URL but completely forgot the port number and, because I have not used my RN's dashboard to access my PMS database for some time (approx. 2 years), I completely forgot how to do it. However, after I wrote out my problem a little light went off in my brain and the RN dashboard/Plex database entry method was slowly coming back to me.
Anyway, thanks for both your help and I am now using the URL method to do some routine updates, usually some film, TV show or album Plex auto facility has got wrong.
Cheers Guys
UK Bob
