Pistolpete11
Jul 14, 2012Aspirant
Accessing ReadyNAS Duo from elsewhere
I'm effectively new to this so would appreciate some help. I have a ReadyNAS Duo (Sparc). Everything I want to acccess is Shared. At home, I can access the files. I have set up ReadyNAS Remote BUT ...
Jul 14, 2012Guru - Experienced User
If you are thinking that your home PC would need to be on use ReadyNAS remote from work, then that is incorrect. So one option is to simply install readynas remote on your work PC
Pistolpete wrote: IAt home, I can access the files. I have set up ReadyNAS Remote BUT I assume that this needs to be running on a PC and I am about to keep the PC only for the 1% of things that I can't do on an iPad, so it will not be switched on most of the time.
Well the short answer is in fact to just set up HTTPS or FTP. There is some more information here: viewtopic.php?f=7&t=63452&hilit=+FTP#p355471 and viewtopic.php?f=23&t=58380&hilit=FTP+passive
Pistolpete wrote: 1. What setting do I have to configure to make the Shared folders available (to me only) on my Work PC - please don't just say 'set up https' or whatever...
If you pick FTP, then I would suggest FileZilla. For HTTPS, you just use your web browser. And of course you can use ReadyNAS Remote.
Pistolpete wrote: 2. What tools can I use to access the files on the Work PC
