Pistolpete11
Jul 14, 2012Aspirant
Accessing ReadyNAS Duo from elsewhere
I'm effectively new to this so would appreciate some help. I have a ReadyNAS Duo (Sparc). Everything I want to acccess is Shared. At home, I can access the files. I have set up ReadyNAS Remote BUT ...
Jul 17, 2012Guru - Experienced User
https://MyIP:Port is what you should be using. You also need to configure "Port" via Frontview, and enable https access for at least one of your shares.
