Pistolpete11
Jul 14, 2012Aspirant
Accessing ReadyNAS Duo from elsewhere
I'm effectively new to this so would appreciate some help. I have a ReadyNAS Duo (Sparc). Everything I want to acccess is Shared. At home, I can access the files. I have set up ReadyNAS Remote BUT ...
Pistolpete11
Jul 18, 2012Aspirant
Some (very) goo news - got into work this morning and decided to try ReadyNAS Remote. It started off failing, and then suddenly kicked into life and works fully for now. Didn't do anything different, but I'm happy.
Thanks for the further tips on HTTPS. I did use Port 443 so that explains why it drops off the number. Good to know.
I will have to recheck my Frontivew set up as I think i may have got something wrong there and I will try this port check too.
