kturcotte
Sep 10, 2012Aspirant
Accessing ReadyNAS Outside of Network
I have a Netgear RNDU6000 NAS. Is there anyway I can access it when I'm OUTSIDE of my home network (My notebook at school for instance)? If router settings are required, I have a Netgear WNDR4500 rou...
mdgm-ntgr
Sep 10, 2012NETGEAR Employee Retired
Try using ReadyNAS Remote (http://www.readynas.com/remote). If you don't have a corporate firewall you should be O.K. There is the ability to enter proxy settings if a web proxy is used there. ReadyNAS Remote provides secure access to your ReadyNAS over a VPN. One of the benefits of it is that you don't need to open ports on your WNDR4500's firewall.
If ReadyNAS Remote won't work for you then other options could be considered.
