G_man1's avatar
G_man1
Act light flashing but nothing is connected.
Hi, not sure if I'm in the right section
I've noticed on my ultra 2+ that the activity light is flashing say twice or three times every 5 seconds or so. When it flashes I can hear my hard drives clicking and clunking away. Its doing this the whole time it's on. I thought this was odd as nothing that I knew about was or should be connected.
I have done some trouble shooting. I turned all my add ons off and still clunking away. I disconnected Ethernet cable and still going. I checked radar and disks are not resyncing.
Any ideas?
Thanks
  • Hey Evan
    I'm using 2 x Hitachi 2tb Part No. OF12115
    Thanks
  • What is disk model of your Hitachi drive?can you download full logs and post smartctl logs here?
  • Where the sytem logs are in frontview there should be a download all logs button click and browse to where ever you want to save them.
  • Is this the log you were after?
    ***** smartctl output for sda *****
    smartctl 5.42 2011-10-20 r3458 [x86_64-linux-2.6.37.6.RNx86_64.2.4] (local build)
    Copyright (C) 2002-11 by Bruce Allen, http://smartmontools.sourceforge.net
    === START OF INFORMATION SECTION ===
    Model Family: Hitachi Deskstar 7K3000
    Device Model: Hitachi HDS723020BLA642
    Serial Number: MN1220F322D53D
    LU WWN Device Id: 5 000cca 369dd456a
    Firmware Version: MN6OAA10
    User Capacity: 2,000,398,934,016 bytes [2.00 TB]
    Sector Size: 512 bytes logical/physical
    Device is: In smartctl database [for details use: -P show]
    ATA Version is: 8
    ATA Standard is: ATA-8-ACS revision 4
    Local Time is: Fri Aug 17 13:05:32 2012 EST
    SMART support is: Available - device has SMART capability.
    SMART support is: Enabled
    === START OF READ SMART DATA SECTION ===
    SMART overall-health self-assessment test result: PASSED
    General SMART Values:
    Offline data collection status: (0x84) Offline data collection activity
    was suspended by an interrupting command from host.
    Auto Offline Data Collection: Enabled.
    Self-test execution status: ( 0) The previous self-test routine completed
    without error or no self-test has ever
    been run.
    Total time to complete Offline
    data collection: ( 24) seconds.
    capabilities: (0x5b) SMART execute Offline immediate.
    Auto Offline data collection on/off support.
    Suspend Offline collection upon new
    command.
    Offline surface scan supported.
    Self-test supported.
    No Conveyance Self-test supported.
    Selective Self-test supported.
    SMART capabilities: (0x0003) Saves SMART data before entering
    power-saving mode.
    Supports SMART auto save timer.
    Error logging capability: (0x01) Error logging supported.
    General Purpose Logging supported.
    Short self-test routine
    recommended polling time: ( 1) minutes.
    Extended self-test routine
    recommended polling time: ( 255) minutes.
    SCT capabilities: (0x003d) SCT Status supported.
    SCT Error Recovery Control supported.
    SCT Feature Control supported.
    SCT Data Table supported.
    SMART Attributes Data Structure revision number: 16
    Vendor Specific SMART Attributes with Thresholds:
    ID# ATTRIBUTE_NAME FLAG VALUE WORST THRESH TYPE UPDATED WHEN_FAILED RAW_VALUE
    1 Raw_Read_Error_Rate 0x000b 100 100 016 Pre-fail Always - 0
    2 Throughput_Performance 0x0005 134 134 054 Pre-fail Offline - 88
    3 Spin_Up_Time 0x0007 132 132 024 Pre-fail Always - 435 (Average 434)
    4 Start_Stop_Count 0x0012 100 100 000 Old_age Always - 15
    5 Reallocated_Sector_Ct 0x0033 100 100 005 Pre-fail Always - 0
    7 Seek_Error_Rate 0x000b 100 100 067 Pre-fail Always - 0
    8 Seek_Time_Performance 0x0005 138 138 020 Pre-fail Offline - 25
    9 Power_On_Hours 0x0012 100 100 000 Old_age Always - 452
    10 Spin_Retry_Count 0x0013 100 100 060 Pre-fail Always - 0
    12 Power_Cycle_Count 0x0032 100 100 000 Old_age Always - 15
    192 Power-Off_Retract_Count 0x0032 100 100 000 Old_age Always - 31
    193 Load_Cycle_Count 0x0012 100 100 000 Old_age Always - 31
    194 Temperature_Celsius 0x0002 181 181 000 Old_age Always - 33 (Min/Max 17/36)
    196 Reallocated_Event_Count 0x0032 100 100 000 Old_age Always - 0
    197 Current_Pending_Sector 0x0022 100 100 000 Old_age Always - 0
    198 Offline_Uncorrectable 0x0008 100 100 000 Old_age Offline - 0
    199 UDMA_CRC_Error_Count 0x000a 200 200 000 Old_age Always - 0
    SMART Error Log Version: 1
    No Errors Logged
    SMART Self-test log structure revision number 1
    Num Test_Description Status Remaining LifeTime(hours) LBA_of_first_error
    # 1 Short offline Completed without error 00% 0 -
    SMART Selective self-test log data structure revision number 1
    SPAN MIN_LBA MAX_LBA CURRENT_TEST_STATUS
    1 0 0 Not_testing
    2 0 0 Not_testing
    3 0 0 Not_testing
    4 0 0 Not_testing
    5 0 0 Not_testing
    Selective self-test flags (0x0):
    After scanning selected spans, do NOT read-scan remainder of disk.
    If Selective self-test is pending on power-up, resume after 0 minute delay.
    ***** smartctl output for sdb *****
    Serial Number: MN1270F33HJEMD
    LU WWN Device Id: 5 000cca 369f155ca
    Firmware Version: MN6OA800
    ATA Version is: 8
    Local Time is: Fri Aug 17 13:05:33 2012 EST
    been run.
    data collection: (18950) seconds.
    command.
    power-saving mode.
    2 Throughput_Performance 0x0005 134 134 054 Pre-fail Offline - 87
    3 Spin_Up_Time 0x0007 132 132 024 Pre-fail Always - 432 (Average 433)
    4 Start_Stop_Count 0x0012 100 100 000 Old_age Always - 86
    9 Power_On_Hours 0x0012 100 100 000 Old_age Always - 1049
    12 Power_Cycle_Count 0x0032 100 100 000 Old_age Always - 86
    192 Power-Off_Retract_Count 0x0032 100 100 000 Old_age Always - 86
    193 Load_Cycle_Count 0x0012 100 100 000 Old_age Always - 86
    194 Temperature_Celsius 0x0002 193 193 000 Old_age Always - 31 (Min/Max 16/37)
    No Errors Logged
    1 0 0 Not_testing
    2 0 0 Not_testing
    3 0 0 Not_testing
    4 0 0 Not_testing
    5 0 0 Not_testing
ProSupport for Business
