fwdnetad
Jun 06, 2016Aspirant
Active Directory issues after 6.5 upgrade
So after the the 6.5 update on our ReadyNAS 516 we are experiencing some weird issues with active directory permission to the NAS. Some users can get right on while other users it just keeps prompti...
- Jun 14, 2016
Hi,
Try to load the latest RC Beta Firmware 6.5.1 and see if it resolves your AD issues. If you're hesitant, continue to work with our support team.
Kind regards,
BrianL
NETGEAR
esbiete
Jun 08, 2016Aspirant
It seems I'm facing similar problems, but I have no user able to enter into the shared drives and continuously ask for credentials.
Doing some test, I've locally (ssh session in the ReadyNAS 314) simulated the connection by using smbclient and I was able to log in with no problem using remote AD authentication (password Ok, Session Ok) and enter into the shared folder BUT unable to do any action like 'ls', as it raises "NT_STATUS_ACCESS_DENIED". I've raised the log level but no significative message that can give me any clue of "who" is denying me access to list or do any action with the folder. In any case I've tried changing permissions to 777 and so, but the same result. It should be something related to smbd, nmbd or winbind...may be.
Now I'm doing a full backup in a secondary storage USB disk and I will try to restore config backup I did when upgrading to 6.5.
