fwdnetad
Jun 06, 2016Aspirant
Active Directory issues after 6.5 upgrade
So after the the 6.5 update on our ReadyNAS 516 we are experiencing some weird issues with active directory permission to the NAS. Some users can get right on while other users it just keeps prompti...
- Jun 14, 2016
Hi,
Try to load the latest RC Beta Firmware 6.5.1 and see if it resolves your AD issues. If you're hesitant, continue to work with our support team.
Kind regards,
BrianL
NETGEAR
jjmb
Jun 13, 2016Aspirant
I am seeing the same as well, exactly as the last post described. FWIW - I am also seeing an enormous amount of DNS query traffic for non existant domains:
_kerberos-master._udp
_kerberos-master._tcp
lb._dns-sd._udp
It looks like the upgrade may have broken something specific to Kerberos for ADS authentication?
John
