fwdnetad
Jun 06, 2016Aspirant
Active Directory issues after 6.5 upgrade
So after the the 6.5 update on our ReadyNAS 516 we are experiencing some weird issues with active directory permission to the NAS. Some users can get right on while other users it just keeps prompti...
- Jun 14, 2016
Hi,
Try to load the latest RC Beta Firmware 6.5.1 and see if it resolves your AD issues. If you're hesitant, continue to work with our support team.
Kind regards,
BrianL
NETGEAR
jjmb
Jun 13, 2016Aspirant
I am seeing the same as well, exactly as the last post described. FWIW - I am also seeing an enormous amount of DNS query traffic for non existant domains:
_kerberos-master._udp
_kerberos-master._tcp
lb._dns-sd._udp
It looks like the upgrade may have broken something specific to Kerberos for ADS authentication?
John
CRPearce
I currently have a thread open that describe issues similar to what's been experienced here. The issue was the dreaded "Import error", but that has since been resolved by having a Netgear engineer remote in and reset some "stuff".
I'm also having a second issue with my other RN 2120 related to my users' inability to access their Home folders (i.e., login prompts followed by "access denied" messages). Looking at the folder permissions, each Home folder has a numeric ID (Unix User, Unix Group) opposed to the domain user account name. These IDs likely reflect the correct user in Unix, but Windows does not know how to interpret them, thus the permissions issues. I have e-mailed my logs (ATTN to mdgm) and am awaiting feedback. In the meantime, manually setting the permissions has gotten me by for now, but that pretty much defeats the purpose of joining the NAS to the domain. At this point, it simply saved me time creating individual user folders.
- Chris
- BrianL2Jun 14, 2016NETGEAR Employee Retired
Hi,
Kind regards,
BrianL
NETGEAR- fwdnetadJun 15, 2016Aspirant
This worked.
- esbieteJun 15, 2016Aspirant
Not fully worked, check my post https://community.netgear.com/t5/ReadyNAS-Beta-Release/ReadyNAS-OS-6-5-Active-Directory-workaround/m-p/1101026#M8539
- Scirocco16VJun 15, 2016Guide
Worked for me. Problems seem to be fixed.
