powellandy1's avatar
powellandy1
Virtuoso
Jul 26, 2018
Adding a 4th 10TB drive to a XRAID array on Pro6 6.9.3 (please reassure me)
Hi
I have a Pro6 on 6.9.3 that had 6x6TB in XRAID2 (single redundancy). I've sequentially added 3x10TB and today added the 4th. It appears the disk was used before (something i'll take up with Amazon) so I destroyed the partition and then restarted.
This time on the volume screen lists 3 different RAID groups (never has done before) and the XRAID on the right is grey not green. I have not consciously chosen to remove XRAID as I want, in the future, to swap out the remaining 2 drives.
Can someone tell me what's going on!
Thanks Andy
Personalities : [raid0] [raid1] [raid10] [raid6] [raid5] [raid4]
md1 : active raid10 sdf2[5] sde2[4] sdd2[3] sdc2[2] sdb2[1] sda2[0]
      1569792 blocks super 1.2 512K chunks 2 near-copies [6/6] [UUUUUU]
md125 : active raid5 sdd4[7] sde4[0] sdc4[6] sdb4[9] sda4[8] sdf4[1]
      9766874560 blocks super 1.2 level 5, 64k chunk, algorithm 2 [6/5] [UUUUU_]
       resync=DELAYED
md126 : active raid5 sdd3[9] sdc3[8] sde3[4] sdf3[5] sda3[6] sdb3[7]
      19510833920 blocks super 1.2 level 5, 64k chunk, algorithm 2 [6/5] [_UUUUU]
      [>....................]  recovery =  0.9% (37969280/3902166784) finish=506.6min speed=127112K/sec
md127 : active raid5 sda5[0] sdb5[2] sdc5[1]
      7811566336 blocks super 1.2 level 5, 64k chunk, algorithm 2 [3/3] [UUU]
md0 : active raid1 sdd1[9] sdc1[8] sde1[4](W) sdf1[5](W) sda1[6] sdb1[7]
      4190208 blocks super 1.2 [6/6] [UUUUUU]
unused devices: <none>
/dev/md/0:
        Version : 1.2
  Creation Time : Thu Feb 13 19:50:28 2014
     Raid Level : raid1
     Array Size : 4190208 (4.00 GiB 4.29 GB)
  Used Dev Size : 4190208 (4.00 GiB 4.29 GB)
   Raid Devices : 6
  Total Devices : 6
    Persistence : Superblock is persistent
    Update Time : Thu Jul 26 16:28:09 2018
          State : clean
 Active Devices : 6
Working Devices : 6
 Failed Devices : 0
  Spare Devices : 0
           Name : 33ea2557:0  (local to host 33ea2557)
           UUID : a425c11d:4b9480fd:8fa2e4ff:906c719b
         Events : 1964648
    Number   Major   Minor   RaidDevice State
       9       8       49        0      active sync   /dev/sdd1
       8       8       33        1      active sync   /dev/sdc1
       7       8       17        2      active sync   /dev/sdb1
       6       8        1        3      active sync   /dev/sda1
       5       8       81        4      active sync writemostly   /dev/sdf1
       4       8       65        5      active sync writemostly   /dev/sde1
/dev/md/data-0:
        Version : 1.2
  Creation Time : Thu Feb 13 19:50:29 2014
     Raid Level : raid5
     Array Size : 19510833920 (18606.98 GiB 19979.09 GB)
  Used Dev Size : 3902166784 (3721.40 GiB 3995.82 GB)
   Raid Devices : 6
  Total Devices : 6
    Update Time : Thu Jul 26 16:27:45 2018
          State : clean, degraded, recovering
 Active Devices : 5
Working Devices : 6
 Failed Devices : 0
  Spare Devices : 1
         Layout : left-symmetric
     Chunk Size : 64K
 Rebuild Status : 0% complete
           Name : 33ea2557:data-0  (local to host 33ea2557)
           UUID : 92b2bc5f:cf375e4b:5dcb468f:89d2bd81
         Events : 13331348
       9       8       51        0      spare rebuilding   /dev/sdd3
       8       8       35        1      active sync   /dev/sdc3
       7       8       19        2      active sync   /dev/sdb3
       6       8        3        3      active sync   /dev/sda3
       5       8       83        4      active sync   /dev/sdf3
       4       8       67        5      active sync   /dev/sde3
/dev/md/data-1:
        Version : 1.2
  Creation Time : Tue Nov 24 12:23:49 2015
     Raid Level : raid5
     Array Size : 9766874560 (9314.42 GiB 10001.28 GB)
  Used Dev Size : 1953374912 (1862.88 GiB 2000.26 GB)
   Raid Devices : 6
  Total Devices : 6
    Update Time : Thu Jul 26 16:22:46 2018
          State : clean, degraded, resyncing (DELAYED)
 Active Devices : 5
Working Devices : 6
 Failed Devices : 0
  Spare Devices : 1
     Chunk Size : 64K
           Name : 33ea2557:data-1  (local to host 33ea2557)
           UUID : 4010d079:27f07b46:33b86d75:a3989442
         Events : 15430
       0       8       68        0      active sync   /dev/sde4
       1       8       84        1      active sync   /dev/sdf4
       8       8        4        2      active sync   /dev/sda4
       9       8       20        3      active sync   /dev/sdb4
       6       8       36        4      active sync   /dev/sdc4
       7       8       52        5      spare rebuilding   /dev/sdd4
/dev/md/data-2:
        Version : 1.2
  Creation Time : Sun Jul 22 21:41:37 2018
     Raid Level : raid5
     Array Size : 7811566336 (7449.69 GiB 7999.04 GB)
  Used Dev Size : 3905783168 (3724.85 GiB 3999.52 GB)
   Raid Devices : 3
  Total Devices : 3
    Update Time : Thu Jul 26 16:22:20 2018
          State : clean
 Active Devices : 3
Working Devices : 3
 Failed Devices : 0
  Spare Devices : 0
     Chunk Size : 64K
           Name : 33ea2557:data-2  (local to host 33ea2557)
           UUID : 1530c06e:fec73963:800bf076:2cf6cf0d
         Events : 5499
       0       8        5        0      active sync   /dev/sda5
       1       8       37        1      active sync   /dev/sdc5
       2       8       21        2      active sync   /dev/sdb5
  • Hi
    So it hasn't worked - finished resyncing - the volume size hasn't grown and it still shows the RAID groups with XRAID greyed out. What can I do from here??
    Tx
    Andy
    md125 : active raid5 sde4[0] sdd4[7] sdc4[6] sdb4[9] sda4[8] sdf4[1]
          9766874560 blocks super 1.2 level 5, 64k chunk, algorithm 2 [6/6] [UUUUUU]
    md126 : active raid5 sdd3[9] sde3[4] sdf3[5] sda3[6] sdb3[7] sdc3[8]
          19510833920 blocks super 1.2 level 5, 64k chunk, algorithm 2 [6/6] [UUUUUU]
    md1 : active raid10 sda2[0] sdf2[5] sde2[4] sdd2[3] sdc2[2] sdb2[1]
    md0 : active raid1 sdd1[9] sde1[4](W) sdf1[5](W) sda1[6] sdb1[7] sdc1[8]
    /dev/md/0:
            Version : 1.2
         Raid Level : raid1
       Raid Devices : 6
      Total Devices : 6
        Update Time : Fri Jul 27 07:39:54 2018
              State : clean
     Active Devices : 6
    Working Devices : 6
     Failed Devices : 0
      Spare Devices : 0
             Events : 1964650
    /dev/md/1:
            Version : 1.2
      Creation Time : Thu Jul 26 16:22:47 2018
         Raid Level : raid10
         Array Size : 1569792 (1533.00 MiB 1607.47 MB)
      Used Dev Size : 523264 (511.00 MiB 535.82 MB)
       Raid Devices : 6
      Total Devices : 6
        Update Time : Fri Jul 27 06:30:25 2018
              State : clean
     Active Devices : 6
    Working Devices : 6
     Failed Devices : 0
      Spare Devices : 0
             Layout : near=2
         Chunk Size : 512K
               Name : 33ea2557:1  (local to host 33ea2557)
               UUID : 911b186b:6f606710:81ff18c2:d960e9df
             Events : 19
           0       8        2        0      active sync set-A   /dev/sda2
           1       8       18        1      active sync set-B   /dev/sdb2
           2       8       34        2      active sync set-A   /dev/sdc2
           3       8       50        3      active sync set-B   /dev/sdd2
           4       8       66        4      active sync set-A   /dev/sde2
           5       8       82        5      active sync set-B   /dev/sdf2
    /dev/md/data-0:
            Version : 1.2
         Raid Level : raid5
       Raid Devices : 6
      Total Devices : 6
        Update Time : Fri Jul 27 07:39:17 2018
              State : clean
     Active Devices : 6
    Working Devices : 6
     Failed Devices : 0
      Spare Devices : 0
         Chunk Size : 64K
             Events : 13331486
           9       8       51        0      active sync   /dev/sdd3
    /dev/md/data-1:
            Version : 1.2
         Raid Level : raid5
       Raid Devices : 6
      Total Devices : 6
              State : clean
     Active Devices : 6
    Working Devices : 6
     Failed Devices : 0
      Spare Devices : 0
         Chunk Size : 64K
             Events : 15523
           7       8       52        5      active sync   /dev/sdd4
    /dev/md/data-2:
            Version : 1.2
         Raid Level : raid5
       Raid Devices : 3
      Total Devices : 3
              State : clean
     Active Devices : 3
    Working Devices : 3
     Failed Devices : 0
      Spare Devices : 0
         Chunk Size : 64K
             Events : 5499
    • mdgm-ntgr's avatar
      mdgm-ntgr
      NETGEAR Employee Retired
      You have a triple layer data volume with md125, md126 and md127 as the three layers.
      That means you've vertically expanded your data volume a couple of times.
      From the looks of things you may have started out with 4TB disks, then moved to 6TB disks and now onto 10TB disks?
      There are only 3 disks showing in md127, sda, sdb and sdc.
      If you look at disk_info.log which disk is the 10TB disk you just added. Is it one of those three disks or a different disk? If so, which disk?
      What does your partitions.log look like? Do you see the same partitions for the other 10TB disk as for the 3 disks mentioned above?
      • powellandy1's avatar
        powellandy1
        Virtuoso
        Hi
        Thanks. sdd is the one that is just added (disk_info.log below).
        Forgive me - I don't know how to interpret partitions.log:
        major minor  #blocks  name
           8        0 9766436864 sda
           8        1    4194304 sda1
           8        2     524288 sda2
           8        3 3902297912 sda3
           8        4 1953506020 sda4
           8        5 3905914280 sda5
           8       16 9766436864 sdb
           8       17    4194304 sdb1
           8       18     524288 sdb2
           8       19 3902297912 sdb3
           8       20 1953506020 sdb4
           8       21 3905914280 sdb5
           8       32 9766436864 sdc
           8       33    4194304 sdc1
           8       34     524288 sdc2
           8       35 3902297912 sdc3
           8       36 1953506020 sdc4
           8       37 3905914280 sdc5
           8       48 9766436864 sdd
           8       49    4194304 sdd1
           8       50     524288 sdd2
           8       51 3902297912 sdd3
           8       52 1953506020 sdd4
           8       64 5860522584 sde
           8       65    4194304 sde1
           8       66     524288 sde2
           8       67 3902297912 sde3
           8       68 1953506020 sde4
           8       80 5860522584 sdf
           8       81    4194304 sdf1
           8       82     524288 sdf2
           8       83 3902297912 sdf3
           8       84 1953506020 sdf4
           9        0    4190208 md0
           9        1    1569792 md1
           9      127 7811566336 md127
           9      126 19510833920 md126
           9      125 9766874560 md125
        Device:             sda
        Controller:         0
        Channel:            0
        Model:              ST10000VN0004-1ZD101
        Serial:             ZA27GA65
        Firmware:           SC60
        Class:              SATA
        RPM:                7200
        Sectors:            19532873728
        Pool:               data
        PoolType:           RAID 5
        PoolState:          1
        PoolHostId:         33ea2557
        Health data
          ATA Error Count:                0
          Reallocated Sectors:            0
          Reallocation Events:            0
          Spin Retry Count:               0
          End-to-End Errors:              0
          Command Timeouts:               0
          Current Pending Sector Count:   0
          Uncorrectable Sector Count:     0
          Temperature:                    36
          Start/Stop Count:               1
          Power-On Hours:                 179
          Power Cycle Count:              1
          Load Cycle Count:               165
        Device:             sdb
        Controller:         0
        Channel:            1
        Serial:             ZA27GSKS
        Firmware:           SC60
        Class:              SATA
        RPM:                7200
        Pool:               data
        PoolType:           RAID 5
        PoolState:          1
        Health data
          ATA Error Count:                0
          Spin Retry Count:               0
          Command Timeouts:               0
          Temperature:                    37
          Start/Stop Count:               1
          Power-On Hours:                 82
          Load Cycle Count:               134
        Device:             sdc
        Controller:         0
        Channel:            2
        Serial:             ZA27FV7C
        Firmware:           SC60
        Class:              SATA
        RPM:                7200
        Pool:               data
        PoolType:           RAID 5
        PoolState:          1
        Health data
          ATA Error Count:                0
          Spin Retry Count:               0
          Command Timeouts:               0
          Temperature:                    36
          Start/Stop Count:               1
          Power-On Hours:                 126
          Load Cycle Count:               187
        Device:             sdd
        Controller:         0
        Channel:            3
        Model:              ST10000VN0004-2GS11L
        Serial:             ZJV03DE8
        Firmware:           SC60
        Class:              SATA
        RPM:                7200
        Pool:               data
        PoolType:           RAID 5
        PoolState:          1
        Health data
          ATA Error Count:                0
          Spin Retry Count:               0
          Command Timeouts:               0
          Temperature:                    38
          Start/Stop Count:               9
          Power-On Hours:                 186
          Power Cycle Count:              9
          Load Cycle Count:               15
        Device:             sde
        Controller:         0
        Channel:            4
        Model:              HGST HDN726060ALE610
        Serial:             NCG9UA9S
        Firmware:           APGNT517
        Class:              SATA
        RPM:                7200
        Sectors:            11721045168
        Pool:               data
        PoolType:           RAID 5
        PoolState:          1
        Health data
          ATA Error Count:                0
          Spin Retry Count:               0
          Temperature:                    45
          Start/Stop Count:               1659
          Power-On Hours:                 19379
          Power Cycle Count:              852
          Load Cycle Count:               2320
        Device:             sdf
        Controller:         0
        Channel:            5
        Serial:             NCG9TPDS
        Firmware:           APGNT517
        Class:              SATA
        RPM:                7200
        Pool:               data
        PoolType:           RAID 5
        PoolState:          1
        Health data
          ATA Error Count:                0
          Spin Retry Count:               0
          Temperature:                    43
          Start/Stop Count:               1607
          Power-On Hours:                 19378
          Load Cycle Count:               2268
        I've responded to your PM.
        Thanks
        Andy
ProSupport for Business
