powellandy1
Jul 26, 2018Virtuoso
Adding a 4th 10TB drive to a XRAID array on Pro6 6.9.3 (please reassure me)
Hi
I have a Pro6 on 6.9.3 that had 6x6TB in XRAID2 (single redundancy). I've sequentially added 3x10TB and today added the 4th. It appears the disk was used before (something i'll take up with ...
mdgm-ntgr
Jul 27, 2018NETGEAR Employee Retired
You have a triple layer data volume with md125, md126 and md127 as the three layers.
That means you've vertically expanded your data volume a couple of times.
From the looks of things you may have started out with 4TB disks, then moved to 6TB disks and now onto 10TB disks?
There are only 3 disks showing in md127, sda, sdb and sdc.
If you look at disk_info.log which disk is the 10TB disk you just added. Is it one of those three disks or a different disk? If so, which disk?
What does your partitions.log look like? Do you see the same partitions for the other 10TB disk as for the 3 disks mentioned above?
powellandy1
Jul 27, 2018Virtuoso
Hi
Thanks. sdd is the one that is just added (disk_info.log below).
Forgive me - I don't know how to interpret partitions.log:
major minor #blocks name 8 0 9766436864 sda 8 1 4194304 sda1 8 2 524288 sda2 8 3 3902297912 sda3 8 4 1953506020 sda4 8 5 3905914280 sda5 8 16 9766436864 sdb 8 17 4194304 sdb1 8 18 524288 sdb2 8 19 3902297912 sdb3 8 20 1953506020 sdb4 8 21 3905914280 sdb5 8 32 9766436864 sdc 8 33 4194304 sdc1 8 34 524288 sdc2 8 35 3902297912 sdc3 8 36 1953506020 sdc4 8 37 3905914280 sdc5 8 48 9766436864 sdd 8 49 4194304 sdd1 8 50 524288 sdd2 8 51 3902297912 sdd3 8 52 1953506020 sdd4 8 64 5860522584 sde 8 65 4194304 sde1 8 66 524288 sde2 8 67 3902297912 sde3 8 68 1953506020 sde4 8 80 5860522584 sdf 8 81 4194304 sdf1 8 82 524288 sdf2 8 83 3902297912 sdf3 8 84 1953506020 sdf4 9 0 4190208 md0 9 1 1569792 md1 9 127 7811566336 md127 9 126 19510833920 md126 9 125 9766874560 md125
Device: sda Controller: 0 Channel: 0 Model: ST10000VN0004-1ZD101 Serial: ZA27GA65 Firmware: SC60 Class: SATA RPM: 7200 Sectors: 19532873728 Pool: data PoolType: RAID 5 PoolState: 1 PoolHostId: 33ea2557 Health data ATA Error Count: 0 Reallocated Sectors: 0 Reallocation Events: 0 Spin Retry Count: 0 End-to-End Errors: 0 Command Timeouts: 0 Current Pending Sector Count: 0 Uncorrectable Sector Count: 0 Temperature: 36 Start/Stop Count: 1 Power-On Hours: 179 Power Cycle Count: 1 Load Cycle Count: 165 Device: sdb Controller: 0 Channel: 1 Model: ST10000VN0004-1ZD101 Serial: ZA27GSKS Firmware: SC60 Class: SATA RPM: 7200 Sectors: 19532873728 Pool: data PoolType: RAID 5 PoolState: 1 PoolHostId: 33ea2557 Health data ATA Error Count: 0 Reallocated Sectors: 0 Reallocation Events: 0 Spin Retry Count: 0 End-to-End Errors: 0 Command Timeouts: 0 Current Pending Sector Count: 0 Uncorrectable Sector Count: 0 Temperature: 37 Start/Stop Count: 1 Power-On Hours: 82 Power Cycle Count: 1 Load Cycle Count: 134 Device: sdc Controller: 0 Channel: 2 Model: ST10000VN0004-1ZD101 Serial: ZA27FV7C Firmware: SC60 Class: SATA RPM: 7200 Sectors: 19532873728 Pool: data PoolType: RAID 5 PoolState: 1 PoolHostId: 33ea2557 Health data ATA Error Count: 0 Reallocated Sectors: 0 Reallocation Events: 0 Spin Retry Count: 0 End-to-End Errors: 0 Command Timeouts: 0 Current Pending Sector Count: 0 Uncorrectable Sector Count: 0 Temperature: 36 Start/Stop Count: 1 Power-On Hours: 126 Power Cycle Count: 1 Load Cycle Count: 187 Device: sdd Controller: 0 Channel: 3 Model: ST10000VN0004-2GS11L Serial: ZJV03DE8 Firmware: SC60 Class: SATA RPM: 7200 Sectors: 19532873728 Pool: data PoolType: RAID 5 PoolState: 1 PoolHostId: 33ea2557 Health data ATA Error Count: 0 Reallocated Sectors: 0 Reallocation Events: 0 Spin Retry Count: 0 Command Timeouts: 0 Current Pending Sector Count: 0 Uncorrectable Sector Count: 0 Temperature: 38 Start/Stop Count: 9 Power-On Hours: 186 Power Cycle Count: 9 Load Cycle Count: 15 Device: sde Controller: 0 Channel: 4 Model: HGST HDN726060ALE610 Serial: NCG9UA9S Firmware: APGNT517 Class: SATA RPM: 7200 Sectors: 11721045168 Pool: data PoolType: RAID 5 PoolState: 1 PoolHostId: 33ea2557 Health data ATA Error Count: 0 Reallocated Sectors: 0 Reallocation Events: 0 Spin Retry Count: 0 Current Pending Sector Count: 0 Uncorrectable Sector Count: 0 Temperature: 45 Start/Stop Count: 1659 Power-On Hours: 19379 Power Cycle Count: 852 Load Cycle Count: 2320 Device: sdf Controller: 0 Channel: 5 Model: HGST HDN726060ALE610 Serial: NCG9TPDS Firmware: APGNT517 Class: SATA RPM: 7200 Sectors: 11721045168 Pool: data PoolType: RAID 5 PoolState: 1 PoolHostId: 33ea2557 Health data ATA Error Count: 0 Reallocated Sectors: 0 Reallocation Events: 0 Spin Retry Count: 0 Current Pending Sector Count: 0 Uncorrectable Sector Count: 0 Temperature: 43 Start/Stop Count: 1607 Power-On Hours: 19378 Power Cycle Count: 852 Load Cycle Count: 2268
I've responded to your PM.
Thanks
Andy
- mdgm-ntgrJul 28, 2018NETGEAR Employee Retired
You can see that sdd was a missing a partition 5. I've added that partition and added that new partition to md127. It's currently doing a resync. Once that's complete the data volume should then expand.
- powellandy1Jul 29, 2018Virtuoso
Hi
Thanks for that.
Will that 'restore' the XRAID (as opposed to what appears to be flex-RAID) as well??
CheersAndy
- mdgm-ntgrJul 29, 2018NETGEAR Employee Retired
This doesn't do anything to change X-RAID versus Flex-RAID. If you're using X-RAID that will be indicated on the Volumes tab.
The reason you have multiple RAID layers is because of vertical expansion. It's normal to have this in X-RAID when replacing disks with higher capacity ones.
