noleafclover133
Apr 13, 2013Aspirant
Adding Drives to RN104
I just picked up the RN104. I started with 2x 3TB Seagate drives. They built the volume (which took a solid 24 hours) and are in RAID 1 / X-RAID. I then added another formatted 3TB drive (same mo...
mdgm-ntgr
Apr 13, 2013NETGEAR Employee Retired
Give tech support a call and post your case number.
You say you formatted the disk before adding it? The ReadyNAS needs to format the disk. It is best to add blank unformatted disks with no partitions.
